[silent:arts] said:Make sure the stereo adjust trimmer is fully open. Try both extrem positions.
Thanks Volker, that solved the problem!
rna said:I made the tb4's from scratch using parts from Curious Audio.
charlievela said:Hey everyone,
Just finished wiring up my build. The only thing i cant figure out is how to wire up the pilot lamp jewel light thing i've got for the front. I think I read somewhere about hooking it up to the heaters. But wasn't sure if that means hook it up to the left AND right heater, or left OR right.
charlievela said:The right channel seems to be working just fine.
The left Chanel isn't compressing unless I have the PR knob fully turned up. And it's not so much compressing as distorting the signal.
I've swapped tubes and optos as well as the PR molex but that doesn't seem to be the issue.
When I have the stereo link enabled with a test tone applied to the broken channel, I'm seeing the correct amount of gain reduction at corresponding settings of the knob. So, if I had signal going through the working channel and was seeing 5db of reduction when the pot was at "6", having the link enabled with a signal running through the broken channel and a pot setting of "6" shows 5db reduction on the working channel but not on the broken channel.
The broken (left) channel gain knob works normally, except when I turn it all the way up with no signal running, I can hear a high frequency modulation in the tubes that isn't present in the right. But the meter seems to track the output just fine, and goes to zero when I flip it to display GR.
Any suggestions for trouble shooting?
charlievela said:Tried swapping transformers and no change. Also tried solder wicking around the molex connectors on the pcb and reflowing. Checked continuity on all my heaters and they're good. I saw that some folks earlier in the thread had a similar issue. Any word on solutions?
charlievela said:I've tried that as well when I double checked the Peak reduction molex
