Foots said:I'm gathering the parts for this project and can't wait to start! I found this video on YouTube (link below) and have a question I'm hoping somebody here can answer. Aside from a couple full kits, this will be my first build on my own.
http://youtu.be/M-lXJtmLrd8
It looks like this builder has done some kind of mod to switch the attack between fast/slow, but I only see one T4B for each channel. Anybody know how he accomplished this? I did find the mod for 2 T4Bs/channel, but this looks different. I've tried to reach out to the builder with no luck so far. Does anybody recognize the case? In his video comments, he mentioned Collective Cases and I've reached out to them. No response yet. [edit: Collective Cases says it's not theirs. I ended up ordering one from another vendor]
Thanks folks! I'm really looking forward to this project!!
QNote said:Hi Foots!
I'm the builder in the video, so I can answer a couple questions for you. First, the Fast/Slow switch is just a dummy switch (sorry to disappoint!). The front panel came with that functionality, but my build does not... at least not this particular build. So, I just included dummy switches for looks. There is also no functionality to bypass or swap I/O transformers.
Second, I can't find where I purchased the enclosure, but my memory told me Collective Cases. If they deny it, then I don't remember where it came from. DIY-Racked, maybe? I do remember that the panel I received looked very different than what was advertised on their website, and they were located out of the US.
Someone mentioned the original BOM is no longer available. I have that, if needed.
QNote
Mouser.com carries several acceptable replacements for the NE-2 neon lamp. I used one of them with no problem. The lamp acts as a voltage regulator, and some have substituted a zener diode in its place. I prefer the lamp, just because that was in the original design and works well.Foots said:1. The 36NE002 neon lamp (ne2 on the board) is obsolete. What did you use in its place, and what does it actually do? At first I thought it lit the VUs, but that doesn't seem possible.
Highly recommended.Foots said:2. It looks like Volker used a heat-sink for the voltage regulator, but others do not. Is this necessary/recommended?
We need more details.JW said:If I have 7VAC at the heaters, what should I change the 100 ohm resistors to?
JW said:Sorry,
Tubes are installed. I'm still getting 7V at the heaters of all tubes.
