I just finished one second Dla2a, or almost...because sound does not pass through it (except when unit is "off").
Some facts :
- I firstly forgot to connect the heaters, during first powering on..i do not know if Something can be broken by this.
- I also missconnected the 7805, it was in the wrong side..i do not know if it can broke something
- Sound passes when unit is not powered on, so no problem at the connection of xlr's
- When unit is powered on, no sound at all
- Neon are illuminated, so as tubes, vu meter find the 0 in "GR" mode.
In my opinion the Relay circuitry is involved there :
- With all Relays Molex disconnected, i have continuity between the 2 pins of "Relay 5V", like it is already switched..It is like this on 3 "Relay 5V" connections. I do not find any short under the pcb...
