audiophreak
Look on the first page of this thread, Compiled Information PDF
audiophreak said:Look on the first page of this thread, Compiled Information PDF
[silent:arts] said:PNK isn't connected to anything on the PCB.
[silent:arts] said:I don't have the data sheets for your transformers handy, but if they do have different ratios you will have different gain settings for the same amount of gain reduction.
audiophreak said:OK , wiring the A-18 in parallel fixed the behavior I was seeing and calibrated better, but there are still the differences you pointed out... so if anyone has a spare A-10 I have a A-18 and A-20 to trade or will purchase outright ... I haven't seen any in Black market or US Evilbay these past weeks.
Thank you for your help , much appreciated
Foots : in the drawing you posted the live main is going strait to PT , use a DPDT switch , mains L&N to bottom pins of switch , Primary lines from PT go to poles ( middle) pins ---------------- BE CAREFULL ---------, the 75k resistor runs between the red wire to the gain pot pin that it goes to in the wiring PDF graphic, as far as the 12v VU bulbs - replace them with 6v and run them from the 5v for relays but make sure you have enough amps for the draw.
audiophreak said:Congratulations Foots !!
The trimmers I have make a tiny "click" as you pass the end of travel , but only in one direction , I think they are Bourns . The two hole thing I just bend the wiper pin tight to the bottom of the housing and solder to one of the other pins.
Hope this helps![]()
