Siegfried Meier
Ok, so testing around some more, I pulled the 723 that was in the +18v side, and I still get the same readings as before...
Umm...what? How is this even remotely possible? I've built up a few PSU's before, and if you pull the voltage regulator, you get no voltage...how am I still seeing 21v on the +18 and 51v on the phantom without that chip? Does this give you any more clues as to what's going on here?
Could the BD237's be bad? Is there any way to test those transistors? I'm assuming the one in the -18v side is fine, but it's possible the + side is bad? Just a thought...
EDIT - I actually JUST noticed that someone has changed the +18v transistor to an NTE184 - not sure if this is compatible or not, but it's not the part that was specified in the parts list?
Looking at that NTE184, left to right, I get 22.3v / 37.2v / 22.3v - this seems unusual compared to the transistors I've measured before...a clue?
