[quote author="matta"]Lagoausente it is nice to see that you are still on the quest for your 'illusive' DAV-1 'high end' mic pre :grin:
Frank thanks for the pics. I hope you are well my friend, miss our chats, all the best for 2007!
I do have to laugh through as the DAV-1 topology is VERY similar to the Green Pre, but uses AD chips instead of TI. I recommended the Green, as did others, to lagoausente back in this thread:
http://www.groupdiy.com/index.php?topic=216156
Which he kind of blew off as not being high end enough, calling it 'mid-level'.... go figure...
Lagoausente, take a look at Franks's photo's and compare them to the Green, if the Green isn't proffesional enough, I doubt that the DAV will be any better :?
Matt[/quote]
I´m not sure how could calificate your actitude. Seems like the kicks to the newbies at school. I really find sometimes mockery as pathetic.
The situation of "unknown" is diferent of be "idiot", but simetimes seems the newbie situation like a perfect "temporal idiot guy here".
But I not against of it, if you enjoy... be happy man.
I just quote what I told:
Green seems a mid level preamp, and quite easy to build.
Is here any clone here of the Universal Audio preamps?
and the reason I tell "seems" is because I was not sure, and as tell along the thread, I had no references, wavs, comparisons, and so was quite lost, situation I have never hiden, and as repeated often on the thread, wanted opinions, references..
About the "DAV illusion", as you tell,first, I didn´t tell the DAV as a "high-end" pre. What i told is that on many blind comparisons was voted over recognized "high-end" pres, what it´s not just the same. And I think haven´t afirmed nothing against, and none in favor of ones and others, just told a about opinions/references from other forums, users etc.
I think you labeled my posts without knowing me at all.
To make you realize of it, note that before I started this thread, I was told by an engeneer that the DAV is a good "mid-range" pre. So you mistake again when you tell me about I´m coming again with the "DAV illusion". Not at all. I started this thread for one reason. I was known it´s based on a IC like the Green, and also that total cost of the components are like the Green, but that´s not the issue. The issue is the blind comparisons made on 3daudioinc, and Gearslutz, where for any reason, the DAV are prefered over the others.
If you go to the 3daucioinc link I posted at start of the thread, you can see on the end one post I made, where I expressed my suspects about any posible compression or something extrange on the dinamics that make people prefer it. So I´m not at non illusion. Just trying to learn theory, surprised? Yes, man, I´m not wanting building the DAV for now, and none the Green for now, but would like to build both on the future when I´ll have some more time. For now, I´ll be upgrading my Mp20 with new opamps, and transformers, while continue searching about electronic/sound.
I write electronic/sound for one reason. Seems sometimes that electronic designers, don´t have the same opinion as sound engeneers, and so my searching will continue on both fields. In this case I was , and I´m looking for a electronic analisis of the DAV (not only what IC uses), and try to find if has any relation with what some people are hearing, because I suspect there is something that makes a subjective preference for the DAV, and much on Classical music recorders. Not that is better, but something that makes people feel as better, something like an added suggar.
And so Matt, if you have light there, I´ll be happy you to switch it on. If you just want be "loughing", then you´ll be happy. :thumb:
