Bonsaimaster
- Joined
- Apr 17, 2013
- Messages
- 218
ruffrecords said:tonycamp said:HI Ian,
how are you? How are you fixed on these boards? I could use 5 of them, let me know
thanx
T
Yes, I still have plenty in stock. Drop me an email with your order and delivery address and I will send you a Paypal invoice.
ian
Dr. Sampson said:Hi there,
I'd love 3 of these boards if you still have any?
Thanks very much!
ruffrecords said:Hi Sebastian,
I think that will basically work OK and a channel switched to mono will be 3dB down on both buses which is fine for panning. Ther is only a could of point to watch. The load seen by the source changes when you switch to mono but most sources should not be bothered by that at all. The other thing is the bus impedance changes slightly when you switch because of the addition of the 2K4 reisstors but, with a total of 32 sources on the bus I do not think this will make any noticeable difference.
barthman.de said:I looked around here in the forum for other ideas to design my summing box. The following features would be fine:
- optional Passive Send (I have a lot of different preamps) and Return to the summing box
- separate Line Send and Return after summing stage to insert or bypass an analog signal path (for Master-Compressor and EQ...)
- output attenuator
I have no experience how send's and return's are designed. Can I do it simple like that?
(for output attenuator I'd like to insert your "24 Step 1K Fader" before Peak/Correlation-Meter and Main Out)
ruffrecords said:I am not sure why everyone seems to use relays for this these days. In my day the insert was simply wired to a normaled pair in a patch bay. If you wanted to insert something you just patched it in. I suppose the relay allows you to compare with and without the insert. Anyway, the choice is yours.
You should be able to. The summing bus will need first to go through a 1:10 step up mic transformer which in turn can be connected directly to the grid of the SRPP stage. The two together should have enough make up gain.mus1k_freak said:Could I run the output of the summing mixer into a pultec srpp type make up stage?
barthman.de said:Maybe I'll get back to you to calculate the shunt resistors for passive summing network but I'll try to find it out alone at first.
barthman.de said:barthman.de said:Maybe I'll get back to you to calculate the shunt resistors for passive summing network but I'll try to find it out alone at first.
Let's try it:
32 channels / every channel: 2 x 5k11 = 10220
impedance: 200 ohm
shunt-resistor: 535,08 --> 536R
Right?
All for stereo. If I switch 8 channels to mono the impedance is changing.
ruffrecords said:I decided to do one last run of 100. Boards just arrived.
currentstatus said:ruffrecords said:I decided to do one last run of 100. Boards just arrived.
Hi Ian
Do you have any boards left please..
