[quote author="SSLtech"]On sheet 2, IC 13 is a pair of flip-flops (IC13a and IC13b) the outputs of which switch a couple of 2N3904's. -Wait. maybe that's not actually a mute...[/quote]
Hi Keith,
Right, the 2N3904's are switching the non-inverting opamp inputs to ground or not (so 'muting' the 'direct' non-inverting path) resulting in polarity-swaps or not for the complete section of opamp+BJT, this because of the inverting input is also looking at the same signal (by means of a few resistors)as the direct non-inv. path. So the BJT is actually 'manipulating' a diff-amp; a diff-amp that has both its inputs tied to the same signal.
It's been a while since I looked at this circuit, but we own several 120s, and I can testify that the LF output drifts in and out of polarity depending on the input level or the settings... so a polarity-opposed pair will drift through cancellation, reinfircement, cancellation, reinforcement... etc.
My polarity-words in previous mails were just about that local circuit-snippet mentioned above, but I can very well imagine that the whole process of dividing & swapping & filtering gives rise to a lot of non-aligned 'dry' (f) & 'wet' (f/2) signals :wink:
[quote author="bcarso"]So every other full cycle of the input signal is polarity-flipped, hence producing a lot of energy at f/2, along with some cuspy high frequency stuff as well.[/quote]
Yep, that's what must be happening based on looking at the circuit. The subsequent filtering gets rid of the high-frequency stuff, but I guess the generated octave down will quite be lagging the original. ... and so can give all kind of enforcements & cancellations, as indicated by Keith.
And about why/where/if the 120-ish circuits differ from the 'usual' octave-down-FX-boxes:
The 120XP seems to differ from the FX-boxes in their use of the dual-FF 4013 in that it has two 'catching areas' (frequency-wise), each with their own flip-flop & polarity-swap section ('near' 60 & 90 Hz, generating 'near' 30 & 45 Hz),
while the FX-boxes do one (& two) octave(s) down.
Maybe that's one of the key ingredients to the supposedly different results ?
Regards,
Peter
