[quote author="SSLtech"]Peter,
I suspect that the Behringer version may be a PLL/tracking osc. sort of model, though it's hard to know for sure. Generally, they don't do well when 'chasing' non-tone-like program, or mixed-tones. The dbx or Rolls version works MASSIVELY better than the PLL approach, which produces unpleasant, atonal "hunting" notes when there's no single clear note to follow.[/quote]
I'd be surprised if they had not simply copied the 'usual' method that octave-down boxes use (Boss OC-2, Pearl OC-7, non-deluxe EHX Octave Multiplexer etc), especially since they were
plasticloning(TM) the BOSS & EHX pedal-ranges anyway.
But who knows they threw in a PLL for grins.
Without having really looked at it in enough detail I guess that the difference in the end-result of the dbx vs FX-boxes is in the filtering-details, since the rectifier & divider & polarity-swappers seem fairly identical. And in addition to that (and likely the more important one) the closer, 'in parallel' bands of the dbX120-something vs the divide by 2 and then once again by 2 of the FX-stompers.
As a test, play an A and an E above it into the Behringer. If it can follow both individually but not together, then it's useless in the dbx application.
I think I see where you're going, it's targeting the spaced bands by a ratio of 1.5, correct ?
The FX-stompers will err here I think, for the reasons above. In that sense (/for this test) the dbx is capable of duophonic action, while the stompers are not.
Regards,
Peter
