damnyankee
arska said:More vca info, correct schematic for vca200
Hi arska,
I gotcha; I missed the 200VCA schematic; the file is mainly on the 202 & 2001 VCA. ;D
DY
damnyankee said:arska said:More vca info, correct schematic for vca200
Hi arska,
DY
That might be true in power amplifiers, but VCAs are a special case. They need to be matched.damnyankee said:According to this article (http://sound.westhost.com/transistor-matching.htm):
"Matched transistors will rarely give you "better sound" (whatever that is supposed to be). In general, distortion will be almost completely unaffected, and there is no influence on frequency response or transient response. What you will get (for paralleled devices) is greater reliability, because the transistors will share the current more equally. "
damnyankee said:Hi David,
Thank you for offering your expertise. I think we're close to cloning the original. All the parts for the main board, 200 VCA & 208/209 RMS are still readily available. The only part unavailable of course is the VU meter (I contacted you about your re-pro'ed meters). Oh, and the original 160VU box; I have no idea how to fabricate that so we're probably going with a standard 19" width rack..
As you are a dbx repair center, I have a question. How much does the "under designed" power supply contribute to the unique 160VU sound? A poster off our other board stated Les Tyler/dbx told him the power supply did play a role. We've discussed this back and forth to keep the original power supply with the LM723 so in your experience, does the power supply contribute to that unique sound? I think Abe is going to build the original power supply yet create jumpers so a modern power supply can be added if the cloner chooses to.
Your thoughts?
Thank you!
damnyankee said:AC,
I think I found us a source for those LM723CH 10 pin voltage regulators. In stock. Under $2 each. I've sent an email to confirm TO configuration, manufacturer, and to see how many are in stock. Keep yer fingers crossed.
As far as the BC263 cross-references to NTE159: Mouser sells matched NTE159's for $3.20 for the matched pair; they run $1.38 each unmatched so heck, isn't it worth 48 cents extra to buy two of them matched?
Finally, the BC109C cross-references to NTE123A: Mouser sells matched NTE123A AND NTE123AP for $3.20 for the matched pair; will this combination work???
Really, the only one I'm stuck on is Q3: KE3687 / U2749. Any suggestions???
DY
