kkrafs
I noticed that in several limiters such as 444, 436 M5136, etc there
is quite a variation on the value of the DC blocking capacitiors.
The first stage might have 100nF, wich pushes the HP corner up a
bit, then between second and third stage we find 25nF, wich put
the HP corner high! (capacitor coupled units)
Now, i find this a bit peculiar or have i missed something?
Another peculiar thing are that several designs uses 100nF
as DC blockers to the rectifying stage no wonder that tube
limiters has a special responce to signals!
Why these values?
For instance comparing this to mic tube preamps i found
eg Neuman uses often 500nF, a significat difference!
I asume that tubes have a quite flat frequency responce! :roll:
For equations to typical designs i use:
http://www.aikenamps.com/Equations.htm
In the case of UA175 i get by above a HP Cf of 419hz
(using mouse on PC calculator wich always hassles!! :twisted:
Wich i find a rather high HP cut point !
Reg
Kkrafs
Why these values?
Reg
Kkrafs
