So I finally began to do my tnc acm-1200 mic mods as the mic fever finally got the better of me.
Actually, I subbed the sino tube it had for a sovtek ax7 and found so much noise as to make it unusable.
So I decided to take a closer look.
Most of what I have read says this mic is the same as the apex 460 with some switches for 10dB pad and a HP filter.
As I worked through the circuit, I confirmed the reported similarity to the apex 460, with a caveat that the inclusion of the HP filter changes the nature of the 'constant current draw amplifier' as most people name the apex 460 amp circuit.
In the tnc acm-1200 mic, the HP filter is implemented as a 100nF poly cap inline between the plate output of the 'grounded cathode amplifier' first stage and the grid of the 'cathode follower' second stage. It also has a 510K resistor to ground at the grid of the CF. The HP filter switch adds a 22nF cap in parallel or not.
This arrangment of course blocks the dc to the grid of the CF changing the bias of the CF stage completely, with respect to the apex 460 circuit. I also found the CF in the acm-1200 has a cathode resistance of 47K vs the 270K in the apex 460 circuit.
Which explains what I see when doing general testing of the acm-1200 : the CF stage is biased real bad
I was seeing something like 146Vdc on the CF plate and some 10Vdc on the cathode and 0Vdc at the grid.
Meaning some 0.2mA current or so and an output signal swing of some 18vpp before severe cutoff of negative peaks.
The thing is almost switched off!
Unless I am seeing something wrong, it seems to me that the biasing is totally crap.
note also the grounding in these mics is very poor, being propagated about the mic via the internal rails and very hit and miss tinned screw pads with easily stripped screws making a poor contact (high resistance to ground) guarranteed !
The pad is implemented as a switched shorting of a 68K resistance in series with a 30K resistance in the plate circuit of the 'ccda' first stage. With the pad switched, the plate resistance becomes 30K vs 96K when not switched.
I think the apex 460 'ccda' circuit is quite a good one, even though many complain it is not.
I've used that topology many times in other amp circuits and it is a favourite of mine.
But the inclusion of the HP filter, implemented as a series capacitance/shunt resistance in between the 2 stages of the 'ccda' renders the whole thing stupid!
I know the mic head amp is not required to provide large voltage swings but 18vpp before clipping into a 11:1 stepdown transformer does not seem right to me.
Especially when the modified 'ccda' in the apex 460 is such a high performance amp - high input Z, very low output Z, reasonably high gain (x25 or so), good drive capability with flat frequency response from 20Hz and -3dB at >20KHz.
So in addition to the other mods usually discussed for the apex 460, I'm restoring the amp circuit to the apex config as well : complete removal of the pad and HP filter circuits and restore the CF to dc bias.(leaving the pad would cause too high a grid voltage at the CF, when the pad is engaged - not safe)
Once I do that, I'll check it all again and decide whether to lift the B+ and stage currents some. At present, I have a 12AY7 in there and I think it is quite starved of current the way it's biased right now.
Common apex mods mods that I am doing are :
- change tube from sino 12AX7 with non sino 12AY7
- replace capsule with the best you can afford
- remove output transformer secondary 'rf caps' to prevent peaking response/distortion
- replace 'ccda' input grid cap with 1000pF polystyrene, 'ccda' output cap with 1uF metal poly
- replace 'ccda' first stage cathode bypass cap with 22uF electro (down from 100uF)
- rebias 'ccda' with first stage cathode resistance of 1K8 (down from 2K7)
and possibly
- add a 250pF 'eq cap' from 'ccda' first stage plate to ground
- add a 220K shunt resistance across output transformer primary to damp resonance of stock traffo
I won't attempt the head basket grill removal - I'm sure I'll ruin it if I try
I am keeping the stock apex output transformer - I'm seeing it perform quite well in my measurements. Should I see anything really bad in phase response or distortion, I'll reconsider.
So far it is just fine.
I'll report back when I do all the mods.
and possibly
