Once Upon A Time, Mouser (and probably others) sold Wallwarts and Linelumps which produced an AC output....IE, a transformer in a plastic box with all the Mains input enclosed
I think those are still available. That is probably a good choice, at these low current levels you could even use a supply without a center tap and just use half-wave diode configuration with a reasonable sized cap on each rail. Also gets the ripple back down into the range that the chips have good PSRR, as opposed to the 100kHz ripple from the DC-DC converter.
Maybe something like this Triad AC-AC wall wart from Digkey, puts out 12V, so after rectifying should be enough to regulate back down to +/- 12 with a low dropout linear regulator:
Triad 12V AC adapter at Digikey
There are other variants, if you prefer regulated 15V output there are 14V AC adapters that would be good followed with LDO, or slightly higher voltage output if you want to use a cheap standard regulator instead of low dropout.
