Winston OBoogie
Correct link : Stephens Tape Recorder Schematics & NotesI am sure you guys have seen this...
Yes I've seen those. What isn't included (unless I missed it) is a schematic of the little plug-in amps (618 & 620 etc.) because, as far as I could determine when I looked through the extant documents from Stephens' estate, John Stephens didn't draw schematics for them.
My recollection of the story is that there was only one lady, Mary, who was trained to make the amp modules for him.
There is no pcb inside, everything being point-to-point resistors and transistors, with teflon tubing for insulation around the leads to prevent shorts etc. There wasn't a whole lot of room inside those cans to get everything wired together, and I wouldn't want to attempt makin' 'em myself.
The only reason I was able to reverse engineer the things was because, along with some tape machines, parts, and documents etc., Audities also had Mary's work bench items and there were a few modules in various states of completion.
I have no desire to keep the schematics hidden and I'd happily publish if it were just my decision.
But I don't know the situation with Audities as far as them wanting to keep the things under wraps.
Best thing to do would be to contact David Kean @ Audities Foundation.
Otherwise, plenty of other discrete circuits to play with so it's not the end of the world
