My3gger said:.. RCA BA-1A has 1uF cap which looks quite small even for this circuit..
DaveP said:Thanks Ian,
Looks like I was in the right ballpark.
Audio1Man said:There is no magic value for decoupling, only good engineering practices and verification.
Power supply decoupling is needed to reduce the HUM, RIPPLE & or SIGNAL from detreating the performance of the product. In the old days a scope was used to check for the problems and with today’s tools we have improved methods. Electrolytic capacitors have typical tolerances that are wide +20%, -50% is not uncommon. They sometime only work @ low frequencies and require additional HF bypassing.
I verify my designs or repairs with a scope and my Audio Precision analyzer to check for noise /signals on the power supply nodes. The Scope has high voltage input tolerance and has a 1 volt output that can connect to and analyzer for Analog or FFT measurements for debugging.
I also use a signal injection method to check the product for correct functions. Using a signal source I drive a current into the node and see what comes out of the product.
Duke
PRR said:All you need to know was in Radiotron 3rd, 1940, chapter 4.
http://www.tubebooks.org/Books/RDH3.pdf {16MB PDF}
DaveP said:The formula for this is in Morgan Jones page 301.
Vripple = half cycle time x amps/ C in Farads
His example with 50Hz power is:-
V ripple(pk-pk) = 0..01 x 0.12/0.000068F = 17.64V
In the US the half cycle time would be 60 x2 so 1/120 = 0.0083. not 0.01
Once you know the ripple and the voltage you can tolerate at any stage it is a simple voltage divider calculation.
For example:
A 10k feed resistor from say 1V of ripple at 2mA and a 10uF cap would be:-
Where reactance of a 10uF cap at 120Hz is 132 ohms
1V x 132/ 10000 + 132 = 0.013V or 13mV.
Obviously a properly designed power supply would have several de-coupling stages before it got to the pre-amp stage described above.
I hope this is helpful
