Bookkeeper said:What is Delta SR? A Mixer?
moamps said:Maybe you can connect outputs from tape replay to headphones directly as is shown in the picture bellow. The drawback is that you can't regulate headphones level for tape replay signal with headphones potentiometer, only you can do that with tape replay level pot. That way meters are left clean from the tape replay signal.
Do you think I could get a copy of the schematic?Thanks for the schematics! I figured that connecting the "tape replay" gain pots first lugs to "headphone" gain pots first lugs will do the trick allowing stereo headphone monitoring for "tape replay" input. And it did, but it also drove the incoming audio from "tape replay" jack to the master meters, which was a bummer since that is not something that Im very interested in metering (rather keep it on the stuff that goes for the tape record out).
Do you think I could get a copy of the schematic?Specs of the CPS450B are:
+/-17V, 3.5A
+/7.5V 1.25A
+48V 0.35V
+24V 1.1A
I f you still need schematics, please PM me your e-mail, I will send it to you.
