pepe
Active member
I would like to hear people thoughts about the discrete versions of PEQ1A (EQP-1A3) and MEQ5. Are they that good for tracking/mastering compared to other equivalents?
And the best part with this project must be its simplicity, and because of that I can’t stop wonder, why are there so few in this forum who actually have built one? Can a project really be simpler than using turret boards and wire point-to-point?
As for the design,
IN -> Transformer -> PEQ1A Filter -> Discrete Amp (16dB) -> Transformer -> OUT
IN -> Transformer -> MEQ5 Filter -> Discrete Amp (10dB) -> Transformer -> OUT
What components would you recommend?
Some thoughts are Sowter 3603 transformers and John Hardy’s 990C discrete amp.
Or should I drop the transformers and use electronically balanced instead?
As for the inductors, Toko is an alternative as well as the more expensive Sowter/Cinemag. But will I gain that much Q-wise and sound-wise if I chose the later ones?
Capacitors: Orange Drop or Wima?
The parts must not be Pultec correct - my goal is rather to achieve a well designed, good sounding, all around EQ to mess with. I would appreciate any input on this.
As for the design,
