Amo Audio
Member
This is probably a really stupid question, but I thought you guys on this forum would know better than anywhere else...
I've been trying to record guitars through a DI box and an amp at the same time. Whenever I put the DI box in the signal, and use the "through" output to the amp, the amp starts giving me really loud radio stations. The DI signal is still fine, and if I go straight into the amp it's fine. I've tried this with many different DI boxes (passive and active), amps, cables, and guitars and it always comes up. The radio stations are the same regardless of wether the audio ground is broken or not.
I'd really like to get this working, any help you could give would be much appreciated. Thanks!
