DI transformer? OPT from st70 dynaco?
shabtek
midwest usa
HI, when I was in coledge studying sound engineering we did a shhot-out whith a bunch of passive DI boxes and an avalon mic pre/hi-z input...
The instructor had a homemade DI which he said was an OPT from a ST70 , a really big for a di tranny. is it gapped? Im not sure how the input/primary going to the bass was wired but the 8ohm secondary was feeding the mic pre input on the mixer.
I don't know if he was cheating the test or something but the consensus was it was as good or better than the avalon!
has anybody heard of this?
Hi Shab,
Please resize your avatar to the recommended 60pixels width - as it is, it takes up a lot of screen real-estate in all the threads you post in..!
For your question - I don't really see how an output transformer should be useable - it has very different impedances that the ones we like for DI-boxes. But yes, you'll get a signal through it surely, just don't expect too much low-end.
Jakob E.
If the direct box is being fed directly from a guitar or bass pickup, the transformer is going to be too low impedance to have good lows, like Gyraf said. If it's an active instrument or keyboard with a low-z output, it might work ok. But it's probably 5-7k ohm instead of the 10k plus that is ideal for a real DI.
Hmm...the Dyna tranny is something like 5k:8 ohms. That's a 625:1 ratio. Load it with 1.5k (typical mic pre input impedance) and you get an input Z of 937,500.
On the other hand, being loaded by 187x its proper termination, it'll probably ring like a bell.
Peace,
Paul
5K:8R is sqr625, that is, a 25:1 winding ratio.
But these transformed impedances tells us nothing about inductances - and it's the inductances that are responsible for how low-end will be transferred, not the turns ratio. It's probably a safe bet that the 5K-side of the transformer won't be over-spec'ed for inductance (because we want as few windings as possible to keep capacitance down, in order not to loose high-end), so it will probably not transfer full frequency range at impedances higher than the rated 5K.
Another thing is that these relatively-big standard-iron cores has quite a high hysteresis-distortion, making them far from perfect for low-level signals like DI. But then again, this might be exactly why it sounds good :razz:
Jakob E.
