Hi everybody, I found this machine I got many years ago from a friend, and I started investigating how these 34mm capsule are made. First Thank you to this wonderful forum and people posting here for all great suggestion I read ! But many questions still need an answer after I tried to Reskin a broken K78 with a simple Mylar from my kitchen (I don't know its thickness... I only wanted to check I could make it )
In the pictures you can see what I did. First I tightened the Mylar to the tensioning ring with its 6 screws,
Next I put the ring on the plate over the loudspeaker. I played a sinusoidal wave of 440Hz and turned the tensioning ring (a threaded ring pushing the mylar out of the plate allows tension adjusting) until I could clearly listen to a resonance in the diaphragm.
Next I put the tensioned Mylar and its ring on the capsule leaving the silver spacer under the mylar and screwed. Final cut and it is done. See pictures for reference.
But I have some questions:
1. I know that the tension of the Mylar affects the bandpass of the capsule, but the question is: in this K87 or in a K47 which is the right resonance frequency?
2. Is there any place where I can buy the Mylar already sputtered with gold? I have many broken diaphragms K47, K67,K87 in my lab and I would like to try Reskin by myself. (The sputtered Mylar you can see in the pictures is broken too)
Thank you in advance!
