I'm looking for an affordable manner to get differential measurements with a scope. The dedicated diffrential probes do exist, but I'm having difficulties in paying hundreds for an accessory that is not used all the time. Most of the time a normal ground referenced measurement or using the two channels simultaneously will get the job done.
I'm interested in audio frequencies, so 20-20000Hz with high integrity is enough. It would be nice to accommodate differential and common mode voltages up to 300V for measuring power supply related voltages without fear of breaking anything, but what I really am interested in are signal level voltages, so <20V is probably enough.
Some alternatives considered so far
1. Dedicated differential amp circuit like INA134 with a separate high impedance input stage with OPA2134 as proposed by the BB data sheet
Good
* Wide enough bandwith
* Reasonable cost
Doubts
* Needs +-18V floating power supply (4x 9V batteries for instance)
* Only for signal voltages -> need overvoltage protection of some sort
2. High quality transformer isolation for the signal (with Lundahl LL1684 for instance)
Good
* Totally passive - no need for power supply
* Could be used for the full input voltage range of the scope
* Bandwith should be adequate
Doubts
* Not cheap even if clearly cheaper than a dedicated differential probe
* How's the trafo behaving when used with very high input and output impedance?
3 Dirty tricks involving the safety grounds
* Not going to even try
4. AC power line isolation transformer for the scope or the unit being measured
* Not willing to try due to compromized safety grounding
5. Biting the bullet - find a used differential probe somewhere
Good
* Works
* Bandwidth beyond what I'll ever need
Doubts
* Very expensive
* Most differential probes are for high voltages - how are they working with small signal voltages?
I'm finding the signal transformer solution (#2) tempting but I'm not sure I got the facts right or missed something totally.
Older scopes (at least) have their signal ground (the BNC connector) connected to the safety ground. I've understood that newer ones may have the signal ground floating. Does this mean that you really do not need a differential probe unless the voltages are too high for the regular probe?
All comments appreciated
-martti-
Good
* Reasonable cost
Doubts
Good
Doubts
Good
* Works
Doubts
* Very expensive
-martti-
