Fortunately is is optional. We will not be taking that option>> The "Williamsonic" circuit requires a -- triaxial BNC-type -- of input connector and that baby costs $30!!! OUCH!!!
How do loss affect how it sounds???Ian,
By better I meant less losses.
Really with that much loss the design is not going to sound much different than a SS or passive version.
The signal will take on tube attributes of sound with the amount of gain. This is why EF86 and 12AX7A alter the sonic character so much.How do loss affect how it sounds???
Ian,
White-Follower: If we are still using the Nixie tube supply the cathode in the top to filament voltage is in violation. Probably not a big deal.
I take it you are looking at these pages:
https://www.tubecad.com/2019/04/blog0462.htm
I got a pair of these in the post this morning. Unfortunately there is no data sheet with them. Is the power in socket centre is positive?
There is a whole bunch of things to consider, some of which are pretty common and easy to specify and others that are less well defined.Distortion, bandwidth and output impedance - are these the main (only) concerns designing the DI? Is there much difference in the output impedance between synths, guitars, basses and other things that we might DI that need to be considered? I feel like I'm missing something? Drive capability?
Blast, I just ordered a regular stomp box style negative centre type. I will have to get a positive centre one as well.Yep, center positive.
You could put a modified quick connect so you can swap polarity too.Blast, I just ordered a regular stomp box style negative centre type. I will have to get a positive centre one as well.
Our bassist had one of those on his DI for live shows. Then one day it fell off, he didn't notice, and the DI went up in smoke at soundcheck! Good times.You could put a modified quick connect so you can swap polarity too.![]()
DI is really only needed for passive pickups, which are all high impedance. Around 1Meg input impedance is standard, although piezos may need more. Most other instruments are active and can be plugged straight into a line input with no need for DI.Distortion, bandwidth and output impedance - are these the main (only) concerns designing the DI? Is there much difference in the output impedance between synths, guitars, basses and other things that we might DI that need to be considered? I feel like I'm missing something? Drive capability?
I got a couple of these in the post the other day and finally got round to trying one out this evening. The HT supply works well and powers up easily to 250V into a 20K load (12.5mA). However, I am having problems with the 6.3V heater output. It will only power up a single ECC88 heater (300mA). It will not power up two in parallel. I don't know of this is something to do with th wall wart I am powering it with but is is a 12V type rated at 1 amp which I would have thought was more than enough. Any ideas?
I had no problem running 600mA for two tubes in parallel. But my wall wart has 12V/ 2A current capability, maybe that makes the difference?Any ideas?
Not so much a complication, just an alternative. Both chips work around 300KHz. Nothing is yet cast in concrete.Im not sure I understand the need for a board that produces ht and lt supplies ,
your obviously going to have a low volt DC supply rail , which can have a linear regulator to supply the heaters ,why complicate things with two chips that opperate at a different frequency ?
