Hello everybody, my first post here! (I thought I already suscribed... but not.)
I'd like to ask you questions about digital pots.
I'm building (slowly!) a full digital system (it started on diyaudio, and I don't even have finished the DAC output so... there's time).
That means of course distant preamps. It also means you have to find a way to control gain...
Digital pots do exist but are very noisy. Is there any that could be used in a preamp gain control? (like that1512). If I'm right (i'm not sure, don't beat me!) "Cohen" topology preamps put the gain resistor in a current feedback loop. Digital pots have a high voltage noise, but lower current noise. So they *may* work not so bad in this place (depends on impedances etc).
Has anyone tried? Do you have some ideas about it?
What are the other ways to do it? I see I could use relays (too big and expensive), reed relays (less big, less expensive, but still big, expensive) or motorpots (you have to servo them and they may be a bit noisy too...).
Thank you,
Nicolas
Thank you,
Nicolas
