some tidbits...
"more range of control, in a series/shunt combination....
"The use of diodes for gain-control presents two opposing problems: the diode impedance
is very non-linear f(r large audio signals (1 volt) and causes considerable distortion; the DC
control signal of about 1 volt, which is required for satisfactory range of gain control,
mixes with the audio to cause "thump". Therefore, reducing the audio signal level across
the diode, in order to reduce the distortion, makes the audio signal small in comparison
with the DC Control sigqlal, which proportionately increases the sound of the "thump".
Using well-balanced diodes and push-pull circuitry is the only solution. However, temperature
variations tend to unbalance the diodes and allow the "thump" to be audible.
Aside from its relatively slow reaction time (5-20 ms) and a slight sensitivity to
temperature, the light-dependent resistor (LDR) is a near perfect gain-controlling device.
The resistance element is very linear, and contributes no measureable distortion to the
audio signal; and its resistance variation of 10 megohms to 100 ohms, with increasing
light brilliance, affords an adequate gain-controlling range over a wide variety of circuit
impedances. In addition, the resistance element and the audio signal have no electrical
connection to the light bulb, or to the DC Control signal, and the "thumping" sound
mentioned earlier is completely eliminated. This isolation also allows the resistance
more...
"Recent research into the use of field-effect transistors (FET), as gain-controlling
devices, has been rather fruitful. In particular, the drain-source impedance of the metaloxide
silicon (MOS) type with an insulated gate exhibits a very dependable change as the
gate voltage is varied. Specific circuit design for high quality performance requires
that the drain source impedance be made more linear by feedback into the gate or substrate,
and that the audio signal across this impedance be limited. Depending on whether the
feedback is taken to the gate, substrate, or both together, the sig_aal voltage limitation can
be 10-15 millivolts, or as high as 50 millivolts, for less than 1% total harmonic distortion.
Since the gate is insulated from the drain-source impedance, the DC Gain-Control signal
cannot mix with the audio signal, and "thumping" is not a problem.
Ail of the gain-controlling devices described above have a simplicity of application
which makes them popular. However, there are several other techniques which are
rather complicated, but should be mentioned:
(a) Chopper, or Variable Duty Cycle - This approach uses
