pucho812
the simple answer is yes. But if you look at the hybrid opamps where it is an IC chip followed by a discrete transistor drive stage, you can make it happen.
Spino said:but is it correct to say that those capi preamps cannot be used with a 5534 in it because it cannot drive the output trafo and such?
I would mostly agree with your statement, however, there are some circumstances where a 553x is not the most adequate choice. Among the reasons for not favouring a 553x are:user 37518 said:With the risk of being flamed, I always thought you really cant do much better than a NE5534/NE5532 considering its price,
They do that without considering the fact that the 990 has an OSI of 1.1kohm, which does not make it particularly suitable for the typical 1:10 xfmr mic pre or even for EQ. However, it will improve the noise performance a in a summing amp.the amount of API discrete opamps I've seen die is simply staggering, even more often than vacum tubes, most of the time I've seen clients replacing them with 990s just to get things going.
ATM, only them (or similar hybrids) can offer 1nV/sqrtHz and 75r drive capability. For what it's worth...So, considering today's integrated opamp technology, remind me, why do we need discrete opamps ?
OPA1622 specs driving 32 ohm (2.8nV rt Hz ein).abbey road d enfer said:ATM, only them (or similar hybrids) can offer 1nV/sqrtHz and 75r drive capability. For what it's worth...
abbey road d enfer said:there are some circumstances where a 553x is not the most adequate choice. Among the reasons for not favouring a 553x are:
When the load impedance is excessive;
+1.... ;DRob Flinn said:There can't be many recordings that haven't be through a 553x chip since it became commercially available.........
Op amps can have a characteristic transfer function open loop (without negative feedback), but once you apply negative feedback, all non-ideal (imperfect) transfer function characteristics are reduced proportionately by the "loop gain margin" or ratio of open loop gain to closed loop gain.80hinhiding said:From what I've heard from endless testing and obsessing is this. Certain IC opamps do have a certain speed and frequency response that some either like or dislike. NE5534 hasn't been my thing so far.. and I've given it lots of time to win me over. I just tested NE5532, which is supposed to be the same as the NE5534 (times two) and without the comp/bal. I preferred NE5532 for whatever reason that is, I don't know. It's still not as nice as the BA283 discrete output design to my ear, by at least 50% for me, but everyone likes something different.
I was trying to like an unknown Class B discrete opamp design and prototyped it once with the iron, and about 5 times on the breadboard. Made tweaks to try and turn it into something I thought I'd enjoy listening to over long periods, and it just didn't pan out. Someone else might love it though. It's more like the speed/cleanliness of a IC opamp. So is it good, yes it is. Anything else comes down to my preference.. and cannot be claimed as better or worse.
This sonic stamp preference, whatever that may be, seems to come down to Total Harmonic Distortion, and speed ... even for capacitors. I'm still learning and don't claim any of this to be what anyone else will like or have to agree with obviously.. ICs are great.. convenient, cheap, sound nice.. and it's true... they're everywhere. SO, no one can argue and say they're not effective or aren't already on countless songs that sound amazing.
A discrete design can have a similar THD to a IC and then there's really not much to talk about.. so isn't the discussion really more about how the distortion overlaps and the rate at which it moves and affects the frequencies.. and whether or not that moves you? That's my conclusion at the moment anyway.
Adam
JohnRoberts said:Op amps can have a characteristic transfer function open loop (without negative feedback), but once you apply negative feedback, all non-ideal (imperfect) transfer function characteristics are reduced proportionately by the "loop gain margin" or ratio of open loop gain to closed loop gain.
I believe I said that but in the context of phase shift. The dominant pole compensation makes the open loop transfer function look like a simple integrator with 90' phase shift.ruffrecords said:I agree with everything you say; I just want to add one caveat. The vast majority of op amps use a dominant pole technique to ensure high frequency stability. However, in very many cases, the turnover frequency of this dominant pole is a few Hz or maybe a few tens of Hz. This means the open loop gain at 20KHz is often 40dB less than it is at 200Hz. This means the loop gain margin also drops by the same amount over the same frequency range and so the benefits of NFB deteriorate by the same amount.
yes, but the point is to keep it small even at 20 kHz... back in the 70's I modified my bench SMPTE IMD tester to use 19kHz and 20kHz instead of 60Hz and 7kHz, specifically to stress op amps in top octave... If you try to measure THD at 20kHz the distorion prodcuts are reduced by the falling gain, two tone IMD creates a IM product down inside the passband.One effect of this is that distortion rises by 20dB per decade across much of the audio band.
As long as the errors are vanishingly small I do not care where the pole is.On the other hand, quite a number of discrete op amps set their dominant pole turnover frequency a lot higher, and sometimes above the audio band. This means the benefits of NFB are spread equally a across the audio band. The downside of this approach is that unity gain stability is often not possible (Neve BA440 for example).
JohnRoberts said:I have heard this argument before (it was pretty big in the 70s) and I am a "show me" kind of guy which is why I modified my IMD bench test to stress the circuitry at 20kHz. It was very revealing for the state of technology back then. Now we have much better ICs but some of the old soldiers are still respectable when properly used.
It's only marginally better than 5534 in terms of noise and 10dB worse than the best.JohnRoberts said:OPA1622 specs driving 32 ohm (2.8nV rt Hz ein).
Which is marginally better than a 5534 in terms of output current but cannot compete in terms of voltage cause only +/-5V rails.OPA 161x specs 1.1nV rtHz ein and +/- 30 mA drive capability
It's a matter of gain; expecting 1nV/sqrtHz @ 20dB gain is a losing battle. But perfect for summing amps that operate at about 30-40 dB noise gain.The uber low noise op amps require the current capability to drive lower resistance feedback resistors to not give up the low ein benefit
80hinhiding said:I also tried using a small value resistor (100R and also 510R) following the IC output before the output transformer, which is 600:600.
A
That's a recipe for LF distortion and attenuation. For best LF response, you need very low drive impedance. Good designs use negative-impedance drive.80hinhiding said:I also tried using a small value resistor (100R and also 510R) following the IC output before the output transformer, which is 600:600.
80hinhiding said:Just observations from a fascinated individual. I would like to know if it's possible to reduce the small amount of DC hum I think I'm hearing with the BA283 circuit, other than getting gapped transformers. Anything that can be done without changing the characteristic sound? I unbalanced the transformer output in this test so maybe that's why the hum is there... only hear when I crank the monitor..
I will look up more about Negative Impedance Drivers. Didn't realize there was such a thing.
Adam
ALL electronic components have problems when they heat up, until the magic smoke that's in them makes them tick is released...efinque said:I remember reading somewhere (sorry, this is very vague) that some op-amps have a problem when they heat up (and some of them have a problem *because* they heat up)
Noise adds up, indeed, but in proportions that are easily predictable. For example, a TL072 is about 4 times noisier than a 5532, so, if a mixer using 5532's throughout was converted to TL072's, it would be 4 times noisier (about 12dB more). Or not...because all the other noises, particularly hum interference and noise due to PSU would still be unchanged, or even lower because the current draw of TL0 is about half of the 5532.They're not really expensive or anything, it's just that for a bigger project where one would need a lot of them it's better to consider whether it's worth it, although with big mixing consoles for example I'd imagine the noise adds up when there are a lot of channels.
There is no significant advantage in replacing 5534 with OPA134 (or 5532 with OPA2134) in a console because the current draw is just about the same and their noise voltage is about 6dB more. The OPA134 family beats the 5532/34 when presented with large source impedances (>50kohm) or when their lower THD is essential.I just looked up and the OPA134 is almost four times more expensive than the NE5534; not really an issue in a small preamp or a DJ mixer but if one was to make a 48 channel console it would definitely be a factor.
There is nothing like a 5531. The original (single) was TDA1034 from Mullard/Philips/Signetics, which became 5534 when licenced to other foundries. The sibling is the dual 5532. There was also an extinct 5539 (single in 14-pin DIL package).efinque said:Sorry I remembered wrong that the 5532 would've been mono but it was 5531 which is why I said 5534.
EDIT : fixed
