DIY 500-Series Pinout
Thee_Aldeen
Member
Wiring up a 500-series enclosure I built + I just wanted to double-check the wiring pinout.
The module I'm wiring is a HairBall Lola.
I'm assuming i'll be wiring:
Pin #1  --  [Chasis]*  -- {IEC GRND}
Pin #2. --  [Output+ (+4)]*{xlr male pin2}
Pin #3  --  [blank]
Pin #4  --  [Output low]*  {xlr male pin3}
Pin #5  --  [Audio Grnd]*
Pin #6  --  [blank]
Pin #7  --  [blank]
Pin #8  --  [Input Low/ GRND]* {xlr female pin3}
Pin #9  -- [blank]
Pin#10 -- [Input Hi +4dbu]* {xlr female pin2)
Pin#11 -- [blank] Gain Adjust
Pin#12 -- [+16vdc]*
Pin#13 -- [GRND]*
Pin#14 -- [-16vdc]*
Pin#15 -- [+48vdc Phantom]*
    155.1 KB
There is a lot of information online. Just do a little research
http://www.51xaudio.com/alliance/index.html
http://www.51xaudio.com/alliance/pinout.html
your STILL not understanding me.. it wouldn't but what i am saying is i am having a hard time differentiating what the pins mean as they are written w/ their technical names and not MALE PIN#2, FEMALE PIN#3 right on the Lola as one might think
I'm not understanding you either, do you mean the pin names in the lola preamp aren't the same as in the picture you attached?
That shouldn't be a problem I assume it's using the standard pinout like every module, wire it as usual, can't see the problem
you are referring to the xlr connections of the rack ? they stay the same either
