Got some measurements and recordings. Measurements were performed by one my acoustical engineer friends in the anechoic chamber at work.
At this point - I think my first experience with the BeesNeez M7 was maybe with a cold solder joint or some assembly issue. It sounded very telephone-y, not a great sound. But the second time I installed it (to get measurements), it sounded much more balanced and full. Super happy with where the mic is at overall, now that I have the BN M7 and a NOS telefunken EF-800 in there.
Was not a huge fan of the Flat K47. In a blind test between the signal sounds and the d-ef47 flat k47, it was extremely obvious which was the signal sounds U47. The D7 had much more low end, much smoother in the upper mids and high end. I preferred it on my voice, anyway. See the last plot for a comparison of all three freq responses.
Comparing all three (and the Mojave), the BN M7 is a huge improvement (on the second try). The BN M7 is extremely close sounding to the takes I got with the signal sounds D7 U47. My D-EF47 had a lower noise floor and I think is slightly better shielded than the signal sounds U47. Still unclear on why the Flat K47 and D7 in my mic are supercardioid, and the Dany D7 in the signal sounds is cardioid.
I’ll try to put together some A/B samples, but the takes are a little rough. Carry on if you want all the plots…
AA Flat K47
First up, here’s the AA Flat K47. Surprised to see that it is more supercard than cardioid.
Cardioid freq response:
Cardioid freq response without head basket:
Omni freq response:
D-EF47 Flat K47 (bold) vs Signal Sounds U47 with Dany D7 (regular):
Beesneez M7
Still wasn’t very happy with the Flat K47, put the BN M7 back in just to hear it again (and to get measurements of that configuration).. And oddly enough it sounded right this time around.
D-EF47 BN M7 Cardioid:
D-EF47 BN M7 Omni:
Cardioid: Signal Sounds U47 Dany D7 (regular) vs D-EF47 Flat K47 (dotted) vs D-EF47 BN M7 (bold):
