Hey guys,
As far I'm still getting not right voltages. For a one day it worked well but then it started to turn of one rail again. What i did is betwen power supply and console there is a 555 timer based delay on circuit. After I turn on power sypply electricity flows threw two 10ohm 50W resistors, after 5 seconds turn on relay and electricity flows directly from power supply to console, that way I'm trying to avoid this first current inrush.
For now i turned off all the consoles modules leavong jsut a thew, and power supply while not plugged gives me 18V after I plugged in Console it reads 8V is it ok with so much drop?? I thought there must be something with the console, bad transistor or capacitor ir leacking. So I measured Amps with all modules turned off and it reads 0.75 amps and power supply drops voltages to 10V, is it ok?
