I have a suggestion for improving the resolution of the cut/boost rotary switch. Perhaps use an arrangement where you have a 12 lorlin type switch as used already, and a 2 pole 2 way toggle switch to choose between boost and cut. That way you would have 12 steps resolution. You could have for instance: 0dB, 0.5, 1, 1.5, 2, 3, 4, 5, 6, 9, 12, 15dB.
On the High EQ the total of all the resistors on the lorlin rotary switch is about 4.7k, so the total on our new 12 step switch would need to be half that at 2.35k (as we are only using it for half the full cut/boost range at a time) and the 2x2 switch would have to be wired to switch in a resistor of the same value in front or after depending on whether cut or boost is selected.
This probably is a little confusing. Let me draw a crude ASCII diagram of the top of the
http://audioxxx.googlepages.com/EQ_169_STD_schematic.pdf diagram, from R23 on the left to R24 on the right:
Original Circuit:
I--*Fully Clockwise end*--0-0-0-0-0-0-0-0-0-0-0--*Fully Counter Clockwise end*--I With -0- representing each step on the 12 step switch
New circuit, set to Boost:
I--*Fully Clockwise end*--0-0-0-0-0-0-0-0-0-0-0-0-*Fully Counter Clockwise end*---*2.35k Resistor*--I
New circuit, set to Cut:
I----*2.35k Resistor*---*Fully Counter Clockwise end*--0-0-0-0-0-0-0-0-0-0-0-0-*Fully Clockwise end*--I
So the 2x2 switch would have to be wired to flip the whole resistor and lorlin 12x1 arrangement.
I hope this helps somebody. Of course, it doesn't stay true to the original. My only reservation was the 5 step resolution. I think this modification could be made with some creative trace-cutting.
Audiox, sorry for putting the cat amongst the pigeons! I truly appreciate the effort you have put into this EQ, and I love the design and how it all fits onto such a compact PCB. Cheers for your efforts!
-Mike C
