Unfortunately... it's broken now...not so!
free personal licenses are still very much a thing
https://www.autodesk.ca/en/products/fusion-360/personal
edit:
Never mind, I found it. Thanks!!!
I use Nanocad (one of a number of free Autocad 2D clones) for creation and SheetCam (£110) for G-code processing. Before Sheetcam, I used HeeksCad, which was quite cheap (£10 IIRC) but is now free, and doesn't seem to benefit from help by the designer any more.im a hobyist. im also retired and dont have the cash for big software packages
Hi,Fair enough, I didn't really say what's going on. I'm doing okay with feeds and speeds. Gotten some decent results. My trouble is something in one of the free softwares is causing problems. My machine is going idle mid cut, and I have to manually intervene and babysit hours long jobs. The other thing, sometimes when I try to abort a job to reset, it drives my bit straight into the material destroying everything. I'm pretty sure these things are software related, but I cannot complain to anyone because they're free.
So I started researching other CAD programs and everything I've tried is so complicated that I haven't gotten anywhere. The ones I mentioned above look easy comparatively, I just haven't gotten used to the idea of paying yet.
I broke a number of tools when aborting a job, because when you ask "Go to zero", it doesn't raise the tool before moving. I do it with a RF remote controller, similar to that one https://fr.aliexpress.com/item/1005...!sea!FR!747477913!&curPageLogUid=jrRmtj7cXiiOThe other thing, sometimes when I try to abort a job to reset, it drives my bit straight into the material destroying everything.
I concur with totoxraymond that you must split jobs in separate operations.I'm pretty sure these things are software related, but I cannot complain to anyone because they're free.
