DIY Gyraf G7 mic in the U47 body
everything is almost done I will test it on weekend.If it works well,I will record my next album with this!
Because the ef86 can be replaced by 6j8,If I could,maybe I will change some tubes from different countries.Try the Dawning's(Shu Guang)6j8, it's a specialty of China.
The PSU is almost done, but I don't know what to put in this "10" place. I purchased the components required by psu according to the list provided by Mr. gyraf. Now there is a 25v2200uf capacitor left. Where is it connected?
Recheck how your diode bridge is mounted.
On the round types, the + and - are usually across from each other, which would be how the PCB is set up.
Your bridge has - next to +, so pinout may not be correct (I didnt dig into the schem or PCB layout, but just wanted to give you a heads up to double check)
Gustav
