michaeljtbrooks
Member
I've had some success with homebrewing large condenser capsules. I wanted to experiment with different capsule shapes and backplate hole layouts, so needed a very cheap method of building them. I also don't have a micrometer tolerance lathe.
After quite a few iterations, I've had some reasonable results with using copper-clad PCB and aluminiumised Mylar in the form of a cheap space blanket.
I've written it up as an Instructable: DIY Large Diaphragm True Condenser Microphone Capsule - From Scratch!
