This capsule is also used in the KM83, KM130 and KM183.kingkorg said:The version i am talking about.
‚Honeycomb‘ reflectors are also used in Schoeps capsules.
Looks great. Where did you get it ? And sound ?kingkorg said:40mm ball arrived today, so here's an update.
Influenced . . .
Project in progress for a Decca tree: fet-version of the M50 idea. UTM transformer.
Don't know if you're using the exact capsule KK showed in his first posts, but to obtain an M50 response, the capsule itself needs the response shown in the first pic. If the capsule has a flat response and is used with a 40mm sphere, the mic will have the response shown in the second pic. The M50's response is the combination of the two curves. For a flat response capsule, you'll want to use a 50mm sphere.Influenced . . .
I used Pronomic SCM1 and Takstar CM-60.Don't know if you're using the exact capsule KK showed in his first posts, but to obtain an M50 response, the capsule itself needs the response shown in the first pic. If the capsule has a flat response and is used with a 40mm sphere, the mic will have the response shown in the second pic. The M50's response is the combination of the two curves. For a flat response capsule, you'll want to use a 50mm sphere.
Aren’t these cardioid capsules?I used Pronomic SCM1 and Takstar CM-60.
Picture of a Takstar capsule and the result after some sawing, filing and sanding.
Cardioid indeed. You have to close the capsule to turn it into omni.Aren’t these cardioid capsules?
