- Joined
- Jul 8, 2010
- Messages
- 470
Thanks everyone for the kind words and support.
I don't recommend using a mult-order filter in the Side channel of MS to provide EEQ unless you want an effect.
There are huge differences between HPF Side in MS and the Allpass-corrected EEQ when the filter is mult-order.
Few people think to look at the resulting crosstalk curves when a second or third order HP is used in Side and reconstructed back into LR. The crosstalk curve peaks horribly and the crosstalk slope - which has a huge effect on the sonic footprint - is still 6 dB/octave. An EEQ is somewhat analogous to a crossover.
An MS approach to EEQ with 12 dB/octave in Side produces peaking:
Allpass correction in Mid provides a 12 dB/octave slope for both Side (vertical) and crosstalk.
You can see the result of Allpassed-Mid here. Left channel is driven. Red is Lateral (mid, mono sum) . Green is Left. Violet Right. Blue is Vertical (side).
Hear the crosstalk difference as it's switched between 6 dB and 12 dB/octave:
https://www.proaudiodesignforum.com/content/EE_12dB_vs_6dB_Crosstalk_Audio.mp3
Ian Stewart did an EEQ comparison here that may provide some additional insight: Center That Sub! (A Guide to Monoing Your Low End) - Blog - Flotown Mastering
