Have you posted these to the technical documents ? Thanks [ I always liked the studers ]
dirtyhanfri said:I'm wondering if it's like in Green pre or Tac Scorpion preamp, just a jumper in a ferrite core?
Spino said:dirtyhanfri said:I'm wondering if it's like in Green pre or Tac Scorpion preamp, just a jumper in a ferrite core?
i've been trying to find out as well. studer original bom and schematics don't report those values (oh and btw, studer original has another L post trafo pre amp stage and a double L pre trafo). from audiox's component layout values pdf it looks like it's marked as FER, so i'd guess a ferrite bead. a friend of mine has one and i'll try in the next couple of days to take a look and get a measure.
ijzerpro said:62.01.0115 2.5Wdg Wideband choke
darkcharly said:Do you have any news on the L1?
Anyone? ???
Spino said:darkcharly said:Do you have any news on the L1?
Anyone? ???
ooops, totally missed this one, sorry.
yes, original L where Philips p/n 62.01.0115. they can be changed with TDK p/n B82114-R-A4.
in italy, they can be found at Distrelec with code 350214.
as for the original common mode choke before the original trafo (parts L1A and L1B on the original studer schem) each single coil measures about 240 mH, and ferrite is indicated as 3E3. no ideas on the wiring though, and no idea of what could come close to that.
hope it helps. any further infos would be great!
shot said:Audiox wrote it's a double-sided board, but in the build documents there's only one-sided pcb copper mirror.
shot said:Difficult part seems to be L1 choke. Does anyone know what is the value of this inductor in henries?
