[quote author="drpat"][quote author="Brian Roth"]
How many program mixing buses (ie, is this only for creating a 40 x 2 for mixdown, or a 40 x 24 for tracking)?
Bri[/quote]
I don't think he'll be doing any tracking with this thing without mic pres!
I like the general idea. I've been looking for something like this for mixing also. I would consider leaving space for EQ's and pres for expandability sake. At least build a bay (or leave room) for inserting maybe 8 patchable EQ's and pres, that fits some standard N*E*V*E or A*P*I 500 modules.
If I were building that thing, I'd go for as simple a path as possible a-la A*P*I. You could do enough home brew 25*20 boards that are floating around here for a few hundred bucks in parts, and tons of man hours.
SSM214x i/o balancing will save you tons over transformers. Metering could be expensive. GSSL comp in the master section??? Just thinking out loud...
Good luck![/quote]
Well, I had to ask about the required busing. I know of more than a few studios that NEVER use the desk's preamps, instead relying upon their stash of outboards.
Re. metering...if only for a 2-bus, then you can spring for a pair of decent ANSI-spec mechanical meters, or perhaps some Dorrough digi-meters. OTOH, if each of the 40 "returns" requires metering...OUCH.
Assuming 40 P&G or TKD slidewire faders at $50 to $125 each, those alone can run upwards of $5000. Decent rotary pots for sends, etc can cost $5 or $10 apiece for quasi-standard (ie, NOT things like reverse audio taper, or duals in anything besides linear taper).
I've been through this drill eons ago:
http://www.brianroth.com/projects/m77/m77.html
and I can say is is a massive undertaking. The metal work was a total b!tch, even when using a decent fabricator. A 40 input desk will be a LONG mo-fo, and you best pay attention to the structural aspects. I learned about "desk sag" from that project, and interestingly enough, that also turned out to be a problem with the Neve (can I say that here?) 8068 desks as well..
But, best of luck with the project.
Bri
