DIY Preamp for DPA MMC Capsules
jarvis
Germany
Hey everyone,
I just wanted to share a recent project of mine if anyone is interested in that. I've had a pair of DPA MMC 4011 capsules laying around for a while and I finally got the time to build a decent preamp for them. A year ago I bought bodies on Alibaba, that are very similar to the DPA MMP series preamps but with lesser quality internals and externals. Getting the insides out and figuring out, how I wanted to go about mounting a PCB in there was a challenge, but I came up with a 3d printed mount that mimics the original DPA mount, making ground contact to the body via a thin sheet of brass that I glued to the outside. The circuit is @rogs ' clever and straight forward OPIC, for which I designed a PCB that snugly fits the internal dimensions of the body and I'm pretty happy with how everything turned out. So a big thank you to @rogs for sharing that design!
Best
Jannis
    2.2 MB
    1.2 MB
    1.8 MB
How's the noise level?
I didn't measure the noise level without the capsule connected so I can't really comment on that. But I put it side by side with a MKH 40, which is very quiet for a small diaphragm condenser, and the only noise I heard were the fans of my computer, that was in the same room. So in real world application it seems to be sufficient for now. But I may actually do a proper noise measurement in the future.
And were those 0201(?)-size resistors chosen on purpose?
They are 0402 resistors that I had laying around from another project when I designed the PCB and I thought, I'd just use those in the build. But they are really difficult to handle with tweezers and hard to solder with my soldering iron, which has a tip that is about 10 times the size of these resistors. That's why the soldering job isn't the best. I think, I'm going to invest in a hot air soldering station soon.
Best
Jannis
But I put it side by side with a MKH 40, which is very quiet for a small diaphragm condenser, and the only noise I heard were the fans of my computer, that was in the same room. So in real world application it seems to be sufficient for now. But I may actually do a proper noise measurement in the future.....
Th MKH 40 has a published A weighted self noise figure of 12dB(A). The OPIC circuit should perform a couple of dB better than that.
In either case it's 'real world' ambient noise that is going to be the dominant noise source, I suspect?
In my case it definitely is. The MMC 4011 capsules have a pretty high self noise of ~20 dB(A) irrespective of the preamp circuit and in my recording environment at home that gets drowned by ambient noise. But I guess in very quiet rooms or in some field recording scenarios there should be a noticable difference.
Best
Jannis
The MMC 4011 capsules have a pretty high self noise of ~20 dB(A) irrespective of the preamp circuit......
According to the DPA spec sheet the 4011 cardiod mic has a max noise figure of 20dB(A) - and that includes the internal mic preamp.
So, unless their preamp design breaks the laws of physics! :) - the capsule noise must be lower than that...
Self noise of 20dB(A) does seem a lot for just an electret capsule itself?
Yeah, me saying self noise was irrespective of the preamp circuit is of course misleading and doesn't really convey what I've meant. The original DPA MMP-A circuit, in which these capsules are measured in the factory, is pretty low noise as far as I can tell (jfet into a push-pull stage and impedance balanced out). So I was pretty sure that whatever circuit I'd use these with, I would not get noise specs that far surpass those on the measurement reports my capsules came with.
Best
Jannis
