How are y'all getting your TT jacks and cable? I assume nobody here is paying 10 bucks US for a cable that you need 48 or more of in some instances. What's the solution here?
+1. I do same as Pucho. Must be an LA thing. I’ve tried Hosa- about 20% were wired to invert polarity and all failed within a few weeks of regular use. That was 10 years ago, so maybe they’ve gotten better.I roll my own. it's pretty easy over all.
I use canare cable, I'll have a part number when I get home. it's basically their quad cable with braided shield.
I also use redco ends which assemble exactly like a standard 1/4" switchcraft connection with a screw on boot.
I have made them for myself and my place, I have made them for clients. They all like the end results.
I can easily do a picture book PDF on how to do so if you are interested.
Simple, can get more connections in a 1ru if you are using TT.So am I missing something when Samson TRS patch bays are 85 bucks on reverb? DIY TRS cables are dirt cheap. Got 5 switchcraft 9625 bays with my console purchase and wondering what the main reason is to go forward with TT besides it being "pro industry standard"
Be careful with Neutrik bantams. The Neutrik plugs with the chrome sleeve thing on the back end of them need a special tool to close them up.I would love to know what canare cable you are using and how you find the redco ends. Have you used the Neutirk ends and do you have an opinion about the redco vs neutrik? I was just about to pull the plug on ordering a bunch of Neutrik ends and I'm not seeing that the redco ends are significantly less expensive.
Honestly, I would take as much information about building these as possible.
(Canare part number)I would love to know what canare cable you are using and how you find the redco ends. Have you used the Neutirk ends and do you have an opinion about the redco vs neutrik? I was just about to pull the plug on ordering a bunch of Neutrik ends and I'm not seeing that the redco ends are significantly less expensive.
The Neutrik TT's with the plastic boot do not need a special tool to close them unless they have changed designs. I usually just solder tip and ring and then I crimp the TT shaft with the shield running outside of the cable jacket. I have been doing it that way with a BNC crimper for a long time. Then the plastic boot just slides over and locks into place. the pain in the ass is if you have to take the boot back off for any reason. That might be the special tool you mention. I have gotten around that with a flat screw driver but it leaves the boot looking ugly.Be careful with Neutrik bantams. The Neutrik plugs with the chrome sleeve thing on the back end of them need a special tool to close them up.
To be clear the type that need the special tool are these https://www.neutrik.com/en/product/np3tt-1-bThe neutral TT's with the plastic boot do not need a special tool to close them unless they have changed designs. I usually just solder tip and ring and then I crimp the TT shaft with the shield running outside of the cable jacket. I have been doing it that way with a BNC crimper for a long time. Then the plastic boot just slides over and locks into place. the pain in the ass is if you have to take the boot back off for any reason. That might be the special tool you mention. I have gotten around that with a flat screw driver but it leaves the boot looking ugly.
Nevermind we are thinking two different TT designs from Neutrik.
I have used the following. It has the plastic boot I mention.
https://www.redco.com/Neutrik-NP3TT-P-B-NP3TT-P-B1.html
But yeah, the point of Bantams is you can get 96 of them in 1U so you can have a reasonable sized rack instead of a monster.
telephone and TT still exhibit the same issue of patching when phantom is on. This is because one side shorts to ground as you connect in. The Same happens in a TRS environment.The real reason why TRS patch panels are not used over bantam is that bantam panels are far better and more reliable (they were created back in the days of manual analog telephone switchboards). TRS should not be used for microphone patching (especially with phantom power on).
thank you for that. always good to learn new stuff. As you have done both kinds from Neutrik. Is there an advantage to the one you mention?To be clear the type that need the special tool are these https://www.neutrik.com/en/product/np3tt-1-b
& this is the tool you need https://www.neutrik.com/en/product/hx-tt-1 which in the U.K is available for £520 excluding VAT (ouch) from Canford audio. £520 is actually the cheapest U.K price, I have seen them for much more than that !!
I have terminated loads of the other type (https://www.canford.co.uk/Products/43-198_NEUTRIK-NP3TT-P-B-BANTAM-JACK-PLUG-Black) that you are talking about & they are no problem. I always specify them when I build cables for clients.
