Do the Selenium rectifiers acts the same as silicon rectifiers?
ln76d
Gallifrey
I have never before used selenium rectifiers and my knowledge about them is really poor.
With silicon  rectifiers we can use much higher than are provided - for example for rectifiing 24V a 600V rectifier is ok - is it the same with selenium rectifiers?
My intuition tells me - yes - but always better to be sure :)
For example i need E150/50 rectifier which probably is 150V/50mA, can i use E350/30 (350V/30mA) instead?
ln76d said:
For example i need E150/50 rehttp://www.groupdiy.com/Smileys/default/tongue.gifctifier which probably is 150V/50mA, can i use E350/30 (350V/30mA) instead?
If your intention is to use it for the rectifier in AKG N12K power supply (HV part), the answer is yes, IMO.
Anyway, be careful with seleniums.
Regards,
Milan
Regards,
Milan
Hi Milan,
yes exactly:) I know that selenium rectifiers are unstable and capricious, that's why i wanted to be sure. Thanks!
JohnRoberts said:
Why use selenium if you can get modern silicon rectifier?
I knew that this would be first question in this topic :D
As above. I want to make AKG N12 power supply clone. Why?
I have most of the parts, including selenium bridge b25/20, resitors, capacitors so why not? :)
I'm curious would this affect to the sound.
Without PCB it's simple construction.
