PRR said:> What are they good for?
Trimming dog toe-nails. I don't think I have used mine for anything else in a decade.
Brian Roth said:My Dremel doesn't get that much use, but years ago I did find one odd for it.
I have maintained many MCI desks for years, and they used button-head screws with hex (Allen) heads to secure the modules into the frame. Over time, ham-fisted techs with crappy Allen wrenches (NOT me! lol) screwed up those screws.
Hate to admit it, but I have used a cutoff wheel chucked into the Dremel to make a slot on the destroyed screw heads so I can then use a flathead screwdriver to loosen the screws.
Bri
Rob Flinn said:I always try an automatic centre punch before resorting to cutting a slot. Using it at an angle in the direction of rotaton sometimes you can get it to shock the screw loose.
iampoor1 said:I havent had much luck doing that in steel chassis with a dremel.
I wonder if i could cut my toenails?PRR said:> What are they good for?
iampoor1 said:Thats a great tip. Never thought of that!
I usually go for the "vice grip around the head trick", but not on customer equipment..... ;D
I have the same knee problem, and I have never been tempted to self-Dremel.JohnRoberts said:I wonder if i could cut my toenails? With my arthritis I can't bend my right knee enough to easily reach the nails for trimming.
iampoor1 said:Another good use for dremel cut off wheels is cutting IEC connector cutouts in aluminum chassis (Done a few silvertone 1484 mods). I havent had much luck doing that in steel chassis with a dremel.
pucho812 said:I can never get 100%$ straight lines with that, it's probably me, a work around is neutral power con if there is space.
Brian Roth said:In the few situations where I resorted to that with the screws that attach the MCI channel modules into the frame of the desk, those are small 6-32 button heads and no way to grab them with a vice grip. I dunno it whacking them with an automatic center punch is viable, either because of the small/low profile of the button heads.
It was a "last resort"measure to be able to remove the screw so the module could be repaired.
https://www.mcmaster.com/button-head-cap-screws
Bri
Rob Flinn said:It does work on the MCI screws as that is what I've used it for, but not all the time. It's a first rather than last resort. Another way you can use the centre punch is sometimes you can use it to reshape the hex hole so the Allen key grips it enough to loosen the screw. If it doesn't work I use a hacksaw blade to cut a slot since I don't own a dremmel.
pucho812 said:have you tried using a screw extractor kit for any of that?
Gold said:No sweat with a Foredom. I do almost all my steel chassis work with it. I do dSub cutouts all the time with a cutoff wheel and a file.
iampoor1 said:I dont have that much patience...
Rob Flinn said:No mainly because I haven't owned a screw extractor kit until very recently, & haven't had problems with MCI screws since I have owned one. I guess the desks I look after I have sorted all the stuck screws now.
