Bonsaimaster said:
Anyone building the Drip UE-100. Thoughts, trills, tribulations?
[list type=decimal]
[*]I don't like Carbon Comp resistors.
[*]Total price for parts is over $6K
[*]I didn't like seeing low voltage capacitors. I like them to be as big as you can fit on the board.
[*]What's up with all these Jumpers? Is it because it could not be done on the PCB?
[*]What grounding is best for rack mount? Shall we ask Merlin?
[*]Not buying into the idea "gold plated tubes" and tube parts are best. If every part of the signal chain was in gold, then, okay, but it isn't
[*]Who here likes RCA plugs? I remember being told years ago, rca plugs are a bad design. Maybe they changed. I don't know, I stay away from them
[*]The tube adapter receptacles. Once the tubes are in place, do we solder or leave it be?
[*]Why do we need a fan for stereo? Could the design be different to avoid this?
[*]The original UE100 had 12.6 volts going to the heaters. Why isn't this version?
[*]Addition parts list BOM doesn't work
[/list]
I just bought the PCB and case. Mouser and Digikey will be around forever, so I want to put my effort getting the hard to get parts first. This DIY stuff disappears off the marketplace if you don't act quick.
