Drive an audio transformer from an AOP. Good or bad idea?
mudevilo
Member
FRANCE
Hello everyone.
I read on an electronics website that it was not recommended to use an AOP to drive an audio transformer.
Transformer which will be used to balance the signal output from a microphone for example whose amplification will be managed by AOP.
The electronics engineer on this website says that it is necessary to insert a transistor-based assembly between the AOP and the transformer, because transistors have a higher current capacity than AOPs.
What do you think?
Thank you for your feedback.
O.
Hello everyone.
What do you think?
O.
As with everything, it depends on the application. Some op amps are perfectly happy driving some transformers, some less so.
