Dual REDD47 in 1U, done!
simonsez
Jakarta, ID
Nice work making it all fit in a 1RU and fairly cleanly too !
I may have to give up my red pcb's to do it your way ,
who's pcb's & transformers did you use ?
I see Cinemag input which number ?
Do both sides measure the same ? [ noise & other spec's ]
Thank's for like it... :)
As usual, I design my own PCB, using CM2511 as input, and custom wound output TX.
Both side measure the same..
I can share the pdf if you need it, but it's dual layer through hole pcb...
