I don't recall ever using or wishing I could find a "dual" reverse audio taper pot. The single reverse audio taper is useful for typical mic pre gain circuits, but even there it's hard to get good gain law around wiper "hop off" region (without secondary process tricks). Perhaps useful in a stereo gain circuit, but tracking could be a concern.
For state variable designs, I prefer using forward log/audio taper but connected potentiometrically (is that a word? I mean as a voltage divider only). Further I don't use end or range limit resistors in series, but connect the pot to ground and parallel with a real resistor so wiper is grounded at low frequency limit and frequency is set by the more precision discrete resistor in shunt.
Pots are notoriously wide tolerance for their actual resistance (typically 20%). They focus their accuracy on taper conformity. You will get much more repeatable and accurate frequency control using the pot in it's strength (as a divider) with higher precision external components to set actual resistances. Note: you want to keep pot impedances low wrt external circuit impedances to reduce impact of tolerance and loading at intermediate frequencies.
With such a topology, the pot is out of the circuit at both extremes so your tolerance is purely the precision of the external parts used. Tolerance between the endpoints is the external component tolerance and precision of the taper which is much better than the 20% bulk resistance spec.
I've been messing with SVF since '70s and it took me a while to figure this out, so you won't see this in my earliest designs, but I've used it in several later designs with good results.
