ferrochrome
- Joined
- Oct 3, 2011
- Messages
- 60
kante1603 said:Looks like you're in a 50Hz area,no?
The peak at 50Hz and the lower level at 100Hz (octave) normally indicates that the hum comes from pre rectifier.Maybe we should have a deeper look to the ground wiring including audio,psu amd safety earth?
Udo.
P.S.:Maybe you can add your location to your avatar/member/name (pardon,I don't know the correct word),that often makes it easier for the other members.
Hi Udo, yes I'm in Norway, so we have 230V 50hz mains going on here. Thanks for mentioning, I've updated the avatar stuff now
Pre rectifier hum: I would think 50hz would be all over tha ac mains and the filter caps in the psu are there to filter the ripple after recitfication.
AC inlet earth is connected directly to chassi - I've never tried to disconnect that.
Ive tried a lot of different grounding points both for psu, 1176 audio grounds, and for stereolink cards now, that is including star ground at mains inlet earth and also star groiund at pin1. Are there any other options for grounding?
