spaceludwig said:
Hi Paul, thanks for taking the time to answer so thoroughly. I appreciate the extra effort you`ve taken to explain things in some detail.
I do have some additional questions. If you find the time to answer I assure you I do not just glance through them.
Other folks have answered many of them, but I'll put in what I can.
Make sure your signal generator's output impedance is 150 ohms
It is 600 ohm. Could I buffer the signal with an opamp to lower the impedance then fine tune with a resistor in series with the output?
That'd work fine. Or do the balanced pad thing; putting 825 ohm resistors as the series resistors in a balanced pad, with 165 ohms as the shunt resistor, gives 153 ohm output impedance, close enough for most purposes. The attenuation will be about -20dB.
That also shouldn't be happening.
I did not have the 20k load. Also, it only happened when I turned the circuit on.
You need to test the whole circuit: transformer, original Yamaha Zobel network, opamp, and the filter in the feedback circuit (that's the RC combination in parallel with the feedback resistor. And feed the whole shebang from a 150 ohm source. All of the parts work together to create the response.
Out of curiosity: I have read that higher resistance have higher noise. Would there be any value in increasing the Capacitor to say .1uF and lowering the value of the resistor to say 100 Ohm and 5 ohm. admittedly the filter won`t be the same value but I`m just wondering if the total noise would be lowered.
Alternately, is there any harm in getting rid of the filter altogether?
Just to make clear to other posters, I'm pretty sure he's referring here to the stepdown filter located in the amplifier's feedback network, R5-R6-C1 not to a filter located at the input.
To the original poster: no, you can't just change R5 to 100 ohms and R6 to 5 ohms. R5 controls the gain of the amplifier, and you'd be throwing away all the opamp's gain; you preamp wouldn't preamplify anymore. Also, lowering R5 to that low a level would mean the opamp's output would have to drive an unacceptably low impedance. Besides, the feedback network, as far as noise is concerned, is in parallel with the input resistor, which is lower. So it isn't contributing significant noise anyway.
Can you get rid of the filter? Yes, but you shouldn't; as I suggested earlier, it's probably necessary to achieve flat result from the transformer-opamp system.
Peace,
Paul
