I am trying to restore an old Dynacord Echocord model Super 61
I have starting with the more straight forward jobs like replacing capacitors and drifted resistors
The motor spins around and mechanical function is ok, i replaced some of the rollers
Unfortunately one of the two playback heads is open and needs to be replaced
I have tried searching on ebay but no luck.
JRF Magnetics is the only supplier of magnetic heads that I am aware of and I have had a quick look at their catalog, but I am unsure what would be a suitable replacement
The working playback head I have measures about 1K ohm on the multimeter, isolated from the circuit. The three recording heads measure 430 ohm and they are all fine
Some readings I have found on another website and seem to confirm at least my resistance measurements. I ignore how to perform the other measurements they done
The 3 recordingheads
Resistance: DC=448 ohm, 120Hz=1090 ohm. 1Khz=16,7 Kohm
Inductance: 120Hz=719mH, 1Khz=636mH, Q=3,9 D=0,256 (at 1Khz)
Capacitance: 1Khz=38,47 nF
The 2 playbackheads
Resistance: DC=1019 ohm, 120Hz=3,73 Kohm, 1Khz=43Kohm
Inductance: 120Hz=2,26H, 1Khz=1,81H, Q=3,46 D=0,288 (at 1Khz)
Capacitance: 1Khz=12,68 nF
This is the JRF catalog page for 1/4" full track width mono heads, model PR-B1F. There are a few different types available, but it seems to me the resistance values are all much lower than what my Dynacord head is measuring, so I am unsure there is actually a suitable replacement, I have tried emailing JRF but no reply yet.
http://jrfmagnetics.com/Nortronics_pro/nortronics_silver/pdfs/p26.pdf
It would be great to understand how to select a correct replacement head as it would be also useful for possible future repairs
The 2 playbackheads
