e88cc heater wiring
Gachet
Bordeaux France
Hi there
sorry for the ******* question:
The e88cc datasheet says heater supply 6,3v parallel.
Here is what I understand:
Supply is 6,3V DC on every pics.
Pic A:
But when I look at schematics using E88cc, it looks more like this:
Pic B:
Wich one is correct A or B?
Pic A is correct. Filament voltage is 6,3 V, both filaments are (internally) connected in parallel between pin 4 and 5.
http://www.alldatasheet.com/datasheet-pdf/pdf/228155/PHILIPS/E88CC.html
I am not sure if V1 or V2 is meant to be the E88CC. Either way, the heaters are 6.3V between pins 4 and 5 (this is not what is shown for V2 in pic A). Pin 9 is not connected to the heaters at all and is usually connected to an internal screen which is normally connected to 0V.
It all made sense when you said that the heaters are already in parallel inside the tube.
I wasn't aware of that,This is why I didn't get it.
Everything is clear now:
6,3v between 4 and 5
9 is shield to GND.
Thanks guys
