substitute
Hello,
I got back some PCBs that I designed using Eagle, the component pads are a little small and I find them difficult to solder. I understand how to change the pad sizes, I just don't know what to change them to. For instance, Gustav's PCBs have always been very easy to work with.
Here's a link to the component library I used.
http://gaussmarkov.net/wordpress/tools/software/eagle/eagle-2-libraries/
Opening up a 1/4 watt resistor (for example) in the editor, the drill size is 0.02755906 which is fine, and the pad size is set to auto. It seems like that amounts to the pad being 0.046 diameter. If I change it to 0.05 it's a slight increase.
So my question is, what's a nice comfy pad diameter for components like 1/4 watt resistors, panansonic chicklet caps, etc?
