Seabstudio
Active member
- Joined
- Jul 6, 2012
- Messages
- 36
Greetings !
I don't know if I can post here for this question
I already build a standalone spring reverb with a transformeless driver for tank for a studio use ( I put a steup transformer and I have 12Vp-p at the tube grid
It work good, but I want to drive more the tank and don't know witch values I need to tweak arround the Tube
If I compare with a "classic " fender transformer drive ( like a 6K6 ) the drive is really more powerfull , I can "hear " the spring move if i put my ear close to the spring on tank...I can't understand why
I follow the Valve Wizard recommandation ; ( See middle / end of this page )
http://www.valvewizard.co.uk/reverbdriver.html
Originally he drawn shematic for ECC82 , but he say " A larger triode like an ECC99 or even a triode-strapped pentode might be used on its own "
But I think values can be ajusted ...if someone can help
Thanks in advance
datasheet
https://www.jj-electronic.com/images/stories/product/preamplifying_tubes/pdf/ecc99.pdf
Thanks in advance
datasheet
